305/65/18 tires on 18x9 wheel + 18
I wanna pull the trigger on some new wheels and tires for my 2023 ZR2. Anyone know or have thoughts on if a 305/65/18 tire and 18x9 +18 wheel with 5.71" back space work? I don't want to level or lift and keep the truck as it is. But I also don't want to rub. Or a does a 0 offset have less chance of rubbing? Thanks!
I have those tires on stock rims which are 5.77” backspace, so I am already close to upper control arm but .06” should be fine. I am real close to rubbing on outside of tire but I think since you are adding .19” you should be fine. The tire size looks good on these trucks imo. Send pick if you pull trigger. Here’s mine with stock rims 305/65 18.
Better check my shit out then!
