About to get my ZR2 HD, but possibly having second thoughts.....
I guess my big concern is that it's not sitting high enough. For example, if I got a 3500 and did a 3" front and 1" rear kit and put on 35" tires, it would sit higher than the ZR2 does. Can you crank the keys a few turns on the ZR2 and maybe do a 1" rear block and get shock extenders? Thoughts?
Show me the maths on that. The ZR2 sits 83 inches at the tallest part of the cab. You can level the front and run 37s with plenty of room. That'll get you 84 ish.
If you want ride height, just get a High Country and a 10 inch Cognito lift with Fox 2.5s and 38s. It'll only set you back about $110k, but that's just how it goes.
