Black OEM Emblems Installed
Looks great! I’m probably going to go the same route for the badges except I want to keep the 2 red still. Do you think it’d be too hard to take the plastidip off the 2 without issue?
I agree...the red needs to stay.
I don’t think it would be too hard. If I were to do it again, I would shake the can longer, and make sure to spray prior to hitting the emblem and sweep across. I did that for the most part but a few passes I started too close to the edge of the emblem instead of off of it and it was a little watery instead of the nice stretchy consistency. 👍🏼
I just plastidipped all my emblems black. Super easy process. Took me about an hour give or take. I’m very happy with how they came out.
Looks great! I've use plasti dip on several emblems and some wheels on my boys Tacoma. It works really well and is surprisingly durable. I've had some on a grill for 9 years and a little cleaning and it looks like new.
Hey folks, I had to take my fender emblems off my 2025 Silverado for a PPF job but would like to put them back on. I didnt take measurements or make a template before removing them and would like to get them back on in the exact location. Does anyone know where I can find that info, or maybe buying replacements come with a template? Last resort, If someone is willing to take some measurements to go off of; that would be much appreciated. Thank you
Received my black OEM ZR2 emblems today. Pulled the chrome ones. Popped the red 2 out and swapped it to the black emblems. The swap is fairly simple. The 2 is held on with a couple of tabs. I removed the 3m tape from the backside of the 2. This reveals the tabs. I used a small screwdriver to push the tabs through. I used a little silicone to help hold the red 2 on the new emblems. Still need to do the grille emblem. The 2 is painted on the black grille emblem. Not sure if I want to paint the red or use red vinyl. Now to change out the Silverado and 6.2L emblems. I really like the contrast on the Summit white.
You should look into some smoked tail lights by Recon. Nice truck!
