Blinker not “resetting” after right hand turns…
Picked up my new 2550HD ZR2 Saturday afternoon. I noticed on my drive home that when I made right hand turns the blinker stays on/doesn't reset. It works normally on left hand turns.
I googled and found a bunch of blinker issues on Colorados, but not much on full size trucks.
Had a problem with it once but went away after I let it sit for a bit. Probably worth trying to disconnect the battery and see if it helps.
This feels mechanical. I can just put light pressure on the stem and it will click back into the normal position.
You’re in Central TX, no one uses blinkers here - should be a non issue. 😉
1st time hearing. dealer visit.
Well, I split time between Houston (lived here the past 32yrs) and central TX. Houston traffic and drivers are by far worse (more aggressive, etc)!
It could be because your right rear bumper is crooked
