Steering wheel rocker button
CanZr2
After driving for about 25 minutes, the left rear selection buttons on the back of my steering wheel quit working. This is only if you dont use them within that 25 minutes. The right side volume ones work fine. Anyone else run into this? Is there a reset I can do?
Shut off the truck. Start back up. Reset. Welcome to the world of GMC
Is there a reset on the unit that we can do ourselves? Sort of like a soft boot?
So my 24 did this for a week or two after they updated the truck. It randomly just started working and hasn't done it since. But if you push and hold the end call button for 30 seconds it restarts the infotainment.
Thanks. I will give that a try. What was the update? Was it to solve another issue?
It was the update to solve the issue that the last update created, which was the update that was to solve the issue created for the one before that, which was the update created to........
What he is trying to say is that the update was for the radio cutting out which they haven’t been able to fix since 2022.
That does seem to work with some of the quirkiness in the infotainment system. However, it never seems to have longevity. Just set your expectations with resets and updates. Some get better results than others.
Same thing here. Had the update done and it seems to be working ok now. Sometimes there’s a lag when hitting the button but it works. The only issue I have now is the front camera cuts out when I’m using it.
My 24 zr2 did not do this. My 25 HC does it all the time. I also lost all volume one day. The left side rocker switch to change channels is really annoying when it goes out on a 1,800 mile road trip and you can’t restart the system without being in park.
