I purchased a used 2024 ZR2 with the 6.2L and 14K just over a year ago that had a S&B cold air intake installed and it has been running great with no problems. Last month the check engine light came on, I pulled codes and got P0106 which is a Manifold Absolute Pressure sensor. Took it in under warranty, they did an update and sent me on my way. 2 days later another P0106, took it in, got a new MAP sensor installed. 2 days later, another CEL. Took it in again and they said I needed to put the OEM air box on. I don't have the factory parts so it will be $1200 installed.
I finally cleaned the filter, clearing codes myself multiple times and looked for used OEM parts to install myself. I figured they'd blame me for installing incorrectly so I think I'm stuck in a corner with only 2k left on the warranty. I just took her in yesterday to have the OEM airbox installed.
Anyone else have this experience? I'm having a hard time believing that an aftermarket CAI could be causing this problem. For background, I hadn't cleaned the filter in the first year, so over oiling wasn't the issue.
I'm also one of the recall VINs without a current solution, so no testing or changing the oil and cap or nothing. Just anxiously sitting tight...
Thanks for listening.
