oilmoneymerch
Just picked up the 2024 ZR2. With the 6.2 in black with the dark essential package, has anyone ever done a professional ceramic coating, or know of any places that can be recommended?
Yes, do a search and you will find lots of information on this topic!Just picked up the 2024 ZR2. With the 6.2 in black with the dark essential package, has anyone ever done a professional ceramic coating, or know of any places that can be recommended?
Right on, hope you dont mind me asking but have you personally had it done and if so what are your thoughts on itYes, do a search and you will find lots of information on this topic!
I've used DIY stuff from Turtle Wax and Adam's. Takes about 4-5 hours for a good polish and ceramic application on a new truck. I've got about $750 worth of tools and accessories, so factor that in.Right on, hope you dont mind me asking but have you personally had it done and if so what are your thoughts on it
Here is a recent post on the topic…Right on, hope you dont mind me asking but have you personally had it done and if so what are your thoughts on it
Right on bro i appreciate the knowledge sharing thank you.I have paint corrected and ceramic coated many of my cars, trucks and bikes over the years. New and classics.
My ZR2 came with Ceramic Pro from the dealer. It’s prob the worst of the brands I’ve seen in terms of water spotting.
Gtechniq CSL and Exo V4 was the best I used - but I did a 40 - 50 hour paint correction process on that vehicle so the starting point was pretty flawless.
Short answer: if it’s a new vehicle I would give it a light polish and use Tec582 applied wet, follow proper washing technique and reapply as needed.
Ceramic coating isn’t worth the time, hassle or money for the negligible difference in performance over the lifetime of the vehicle.
Washing isn’t that much easier and it doesn’t stay that much cleaner. YMMV.
All it’s really done is turn car valeting into the “detailer” trade which is a bit of a money grab.
I am not a detailer by trade and never will be.
Then it either wasn't done properly, wasn't prepped correctly or they used a spray ceramic versus the "professional" way of doing a ceramic. Most ALL ceramic coatings have a minimum 2-3 year warranty. Who did it and what did they use?Had mine paint corrected and ceramic coated. It looked great for a a few weeks, but that's about it. Probably wouldn't do it again.
I would have to look. I was mainly just having PPF done, but they threw in some CC so it was probably not the best product.Then it either wasn't done properly, wasn't prepped correctly or they used a spray ceramic versus the "professional" way of doing a ceramic. Most ALL ceramic coatings have a minimum 2-3 year warranty. Who did it and what did they use?
I bought my Black ZR2 end of November. Had local shop that has ceramic’d all my vehicles apply it to my truck. Worth every penny. I went with Adams ceramic coating. Good for 9 years. Good luck! My truck is going into the shop on Tuesday for a 1.5 leveling kit and new Fuel “Rebel” wheels and BFG All Terrains. 295/70/18. I hate the stock rims. Truck is black and Chevy throws in Chrome and gold accent wheels. Don’t like the Goodyear Mud Terrains either.Just picked up the 2024 ZR2. With the 6.2 in black with the dark essential package, has anyone ever done a professional ceramic coating, or know of any places that can be recommended?
You are spot on. I have done it myself several times and it only gets a bit more complicated if the color is dark and needs paint correction. If you have the right tools to do it, it's a no brainer and a HUGE money saver. Surprised to see how many folks will spend $1500-$2500 to do something so easyhonestly you can do this yourself...the ceramic coating itself you can buy for 100 or less...its the labor u are paying for. save yourself 1k...especially if you have a garage big enought to park your truck in. its not rocket science at all..
pre wash
wash
decontaminate : iron remover then spray off
clay bar with detailer
polish truck
apply ceramic coating of your choice...
i havent done it myself -- but those are pretty much the steps necessary. the only reason i havent done it is because my truck cannoot fit into the garage and my lazy ass would need to wake up really early to begin the process outdoors - plus i would need to buy a decent oribital polisher.
heres a really good step by step on how to do it. some of the steps can be removed.
What's the dollar difference between pro and done by yourself even after purchasing everything you need. Also, does it take longer to do on your own and is the product the same as pro?I had it done to two vehicles and will never own another vehicle without it. I am like @AXE where I bought all of the polishing tools and high quality products years ago to do my own paint correction and ceramic coatings going forward. It is not hard to do at all with the right products. To spend $1500-$2500 to have this done "professionally" is just crazy to me unless you don't want to be bothered with doing it yourself...which I understand many will not. gtechniq, Adams, R1 are just a few of the DIY ceramics that are awesome.
You can buy a nice polisher for well under $200...closer to $150. You can buy quality pads for under $30. Polish is cheap...a great quality polish is under $20. To do iron removal, that cost less than $20 for a bottle. A clay mitt is about $30-$40. You, most likely, already have a good quality soap. They make ceramic paint prep you can buy, but you can also wipe the entire truck down with 90% Isopropyl Alcohol before applying the ceramic. The ceramic itself goes on very easy. Just read the directions and, when it "flashes", you just wipe it off and move onto the next section of paint.What's the dollar difference between pro and done by yourself even after purchasing everything you need. Also, does it take longer to do on your own and is the product the same as pro?
Just wondering which route I should go.
WOW that's not bad at all....The only issue I can see in my situation is not having a covered area that can get wet. Mine would all need to be done outdoorsYou can buy a nice polisher for well under $200...closer to $150. You can buy quality pads for under $30. Polish is cheap...a great quality polish is under $20. To do iron removal, that cost less than $20 for a bottle. A clay mitt is about $30-$40. You, most likely, already have a good quality soap. They make ceramic paint prep you can buy, but you can also wipe the entire truck down with 90% Isopropyl Alcohol before applying the ceramic. The ceramic itself goes on very easy. Just read the directions and, when it "flashes", you just wipe it off and move onto the next section of paint.
With all of that being said, for under a $250 investment, you can do it yourself and save a TON of money. What it really boils down to is 1. do you have the time? 2. Do you have the patience to spend a day detailing your truck? If you answer YES and YES, than I highly suggest you give it a try. Once you do, you will never take your vehicle to a "professional" ever again unless the paint correction that needs to be done is way more than you want to tackle.
