🛠️ Member Build Finally getting around to doing some modifications to my HD
Nice info. I saw Viair but thought they might be additional tanks.
Looks like links are not working.
Oops, They should be fixed now. Always have trouble imbedding links off my phone.
Yeah, Pics aren't great. I just took a few in a hurry. It was late and I was tired haha. Here is the same compressors in my other truck. Little better picture of them on the mounts.
Guess I could update this post. I ended up deleting my Bose amp with a PAC AP4-GM71. Stereo sounds great and this is a much better option then trying to tune around the factory amp. The PAC also allows you to adjust the Chime volume or mute them all together. If you turn the chime volume down all the way it also effects the blinker sound. But if you mute the chimes and leave the chime volume up the blinker sounds stay and just the chimes go away.
I also ended up Adding AirLift bags part#88408. They just released them a few weeks ago specifically for a ZR2. They come with cradles so the suspension can fully droop and you can run the bags at zero or open. I connected them to my existing onboard air setup using vixen air suspension valve with a switch mounted in the console.
Push up on the switch the bags air up, push down and the bags air down. The air gauge shows the psi in the tanks on top and the psi in the bags on the bottom. Bags are working great! I also added a charging point that stays on all the time in the same spot. 100w PD usb C so good for charging laptop or tablet.
And last but not least I replaced my exhaust the other day. I originally had a Magnaflow muffler put on right after I got the truck. It sounded good, but it droned some at 17-1800 rpms. Which happens to be about where the truck sits at 75mph on the interstate, lol. So I replaced it with a Borla catback for the 6.6 gas.. it sounds pretty good. A little quieter and the tone is higher pitched. But doesn't seem to have any drone! So definitely an improvement.
The Borla is also a side exit which I like better. Hooking up or unloading stuff out of the bed with the truck running kinda of sucked with the rear exit. Especially on a hot day.
Guess I could update this post. I ended up deleting my Bose amp with a PAC AP4-GM71. Stereo sounds great and this is a much better option then trying to tune around the factory amp. The PAC also allows you to adjust the Chime volume or mute them all together. If you turn the chime volume down all the way it also effects the blinker sound. But if you mute the chimes and leave the chime volume up the blinker sounds stay and just the chimes go away. View attachment 22980View attachment 22981
Hey 8ball- I have question about your PAC AP4-GM71 install, I was hoping you could tell me which PAC AP4-GM71 data harness you used? I'm in the process of installing one too. The closest I found was the (E) harness. All its pins hit wires in the factory plug but not all the wires. I'm guessing not all are needed. I had a BOSE harness by A.I.S. (Audio Integration Solutions) for my AC D-6.1200, I tried to tune it to get it to sound good to my ear and was never successful. So I'm going to give the PAC a try. I also replaced all the speakers with Infinity's. Thanks for your great posts and any insight/help on my current issue
ODAVE
ODAVE
I replied to your DM, but ill post it here too. I should have mentioned it in my post.
ZR2 uses harnesses A and E. You also want to download the V24 utility from PACs website to be able to adjust the settings for it. Chimes, hands free, ect
Looking Good!!! Still liking the Borla?? I'm thinking of doing that next.
Yes sir, Borla has been awesome. Sounds good and no drone. Only one negative with it. It runs a little too close the the passenger side shock IMO. Doesn't touch or anything, but I plan on adding a heat sheild or a couple wraps there. Im guessing they designed it for non ZR2 trucks. Since it does still fit with dssv shocks they just ran with it vs changing the kit. Id still go with it again, but a hair more clearance between the shock body would have been nice. Next time I have the truck on the lift ill see if I can get a decent picture of it.
ODAVE
BTW your install looks great! Very clean. I know how tidies that can be. I got a little lazy on mine thinking it was behind the seat and no one would ever see it but me. I mean I then turned around and posted a picture of it on the internet 😅
Thanks for the .
Thanks 8ball. The usb cable is a great idea. I'm going to get 2 and have one for the DSP amp as well. Hopefully can get to it next weekend to finish.
Thanks for the .
Np, that's exactly what I did. Both cables are rolled up tucked away under the seat. Makes it way easier if you need to change any settings. I used this one for the PAC it has 90 degree micro USB that works in any direction like a USB C plug does
