- Jan 15, 2023
- 1
- 0
- #1
Good Afternoon,
New ZR2 owner here,
Anyone have experience installing this option for leveling the ZR2? Fitment indicates it would fit a 2023.
ReadyLIFT Plus 1.75" Leveling Kit :: 2019-2022 Silverado 1500 Trail Boss 4WD
Fitment: 2022-2023|Chevrolet|Silverado 1500|ZR2|V8 6.2L
www.levelupsuspension.com
To each his own but typically it’s for a couple reasons, remove the rake as some folks hate that look and/or to to clear a wheel/tire setup they are trying to achieve.Just curious as I have never done this...why would anyone want to do this??? Is it solely to eliminate the rake from front to rear? Do folks think the truck looks that bad stock? Thanks
I can understand the need for tires and wheels.To each his own but typically it’s for a couple reasons, remove the rake as some folks hate that look and/or to to clear a wheel/tire setup they are trying to achieve.
This is my issue as well. Kits all fit great but the key is finding the right and GOOD UCA to use on it. On another forum I'm in the parts guy from GM dealership said the stock UCA's are very brittle and wouldn't hold up long with a level added.As someone who has uca failure on my TB, I’m staying far away from any leveling kit that doesn’t include new control arms.
I think I’m having this issue. I told the local shop that I needed UCAs with the level and they insisted that I didn’t. They also said I don’t need to regear for 35s but now I even hit a speed bump and my front end sounds AWFUL. I’m kinda afraid to drive it. I took it back to them and they basically said it’s not their problem that it might be a factory defect. The truck is a year old.As someone who has uca failure on my TB, I’m staying far away from any leveling kit that doesn’t include new control arms.
Thanks! Yeah the sound is much worse than normal. I’ve done levels and lifts many times. The zR2 is different and not a lot of info out there. Guys in this thread are saying that if you only put a leveling spacer, it will break the control arm and I’m afraid that’s what happened here and I’m wondering what else it has the possibility of damaging because it sounds like the front end is gonna fall off when I hit a speed bump or anything of that size That causes a range of motion on the front suspension more than just a slight bumpA reputable shop will lift the truck via the frame and get the front end off the ground. Then with leverage check to ensure there is no movement - ball joints, tie rods, knuckles, etc. It’s been my experience, If you level a truck, it may very well feel different or even bad suspension wise and it will put more stress on front end components.
Re-gearing, I have no idea, don’t a lot of wheel and tire changes in my day and never re-geared anything nor had any issues in this department so can’t weigh in here but seems like a stretch to re-gear? Outside my wheelhouse though, I suspect others around can help here.
Thanks!I would put a set of Cognito arms on and see if it gets better. May want to try a different ship if they can't properly diagnose and fix it.
Getting ready to add my Peak 2.25" level and some bigger rims and tires. My buddy did the same to his and definitely recommends getting it regeared once putting the 35's on. Said it didn't take long at the dealership.A reputable shop will lift the truck via the frame and get the front end off the ground. Then with leverage check to ensure there is no movement - ball joints, tie rods, knuckles, etc. It’s been my experience, If you level a truck, it may very well feel different or even bad suspension wise and it will put more stress on front end components.
Not sure I’m following…are you talking about tuning to account for the tire size difference and speedometer? Regearing isn’t a quick dealership thing, unless I’m misunderstanding the context?Getting ready to add my Peak 2.25" level and some bigger rims and tires. My buddy did the same to his and definitely recommends getting it regeared once putting the 35's on. Said it didn't take long at the dealership.
Sorry, yes that is what I'm talking about. SorryNot sure I’m following…are you talking about tuning to account for the tire size difference and speedometer? Regearing isn’t a quick dealership thing, unless I’m misunderstanding the context?
