New used ZR-2, lockers not Working, bad Fuel Mileage.
Question: With the Ford 2.3L I4 engine, it's setup to run w/either regular 87 or high test 91+ fuel. With the High Test, the computer corrects for the fuel, adding more HP.
With Regular 87, the HP is said to be around 270, while w/91+, it's 300+ HP.
The GM 2.7 I4 is said to be 310 HP, but is that w/just Regular 87?
If it is, then using 91+, does the HP increase using it?
No, the engine is tuned for the 87. Just like any vehicle unless the tuning is present then it is actually making less HP. The higher octane fuel has additives that allow for a higher compression (retardation) with no detonation. The vehicles that have a requirement for higher octane can run on lower octane however, the mpg's will drop. The EPA sticker that is on the vehicle is certified to that MPG using the higher octane. It help the fleet average for the manufacturer.
The use of no ethanol is not about octane it is about the energy for me. This will explain for those that are interested.
So your saying, the GM 2.7L I4 enine, which is advertised as having 310 HP, is doing so using 87 octane fuel only, and that there is nothing built into the system, like the Ford 2.3L I4 has, that improves it using 91+?
I wouldn't sweat the oil and filter change from the dealer. The oil and filter will be more than adequate.
I changed approximately 15 gallons of oil this past week on two skid steers, a 125kW diesel generator, a 2500HD Duramax, and a motorcycle. I used Rotella T6, Rotella T4, Mobil Delvac Extreme, and Honda oil. I used Wix, Bobcat, Napa, and Mobil 1 filters. Never once did I think about what was used, cause I know they are all quality products.
Work slowed so I Just finished deep cleaning the ENTIRE air intake system including....the throttle body. Spraying, scrubbing and rinsing.....Completely degreased the engine and scrubbed and sprayed everything down... Then changed both filters, 6-6.5 quarts of Pennzoil ultimate Platinum 0W-40/ 2 quarts Lucas synthetic stabilizer and still have to finish the coolant flush, new spark plugs,.... I chose the Bosch double iridium and the trans-filter change out And finally an AC system purge and refill. 48,540K now and still runs like a raped ape.
Very blessed and happy with my purchase 👍
New tires coming this week also... I like the KO3s, bust saw a different style Nitto the other day and it had fantastic side tread stance... Forget the name? ... Definitely need something with more than a 2.5 ply. Getting prices together in the next couple days... Ripped one of my tires open completely and lost the sidewall so I'm riding on a spare. Hit the perfect sized v-shaped rock hiding behind a bush on a trail .. I mean it looked like an ax head almost at just the right angle...Last weekend out in the trails... Trying to schedule time to get it all done at once almost impossible. Always doing something...
I agree with @AXE about the oil... As long as it's changed properly is all that matters and it has enough. My dealer doesn't care about the brand..... Or for Lucas additives. He said just keep track of all my receipts in case the engine blows and I'll have everything I need for that 150K warranty. I do most of my own work or have another trusted source to it
I never take my stuff to the dealership unless it's a dealership only issue... Never had a warranty problem. Haven't used too much of it but, it's always been pretty straightforward with this dealership.
All GM is really going to care about is..... Getting the proper area serviced and
are you caring for your truck properly.... and at proper intervals, with proper parts....
If so,.... just keep your receipts and you should be fine with any reputable third party business doing work on the vehicle for a much cheaper price than the dealership will do it for, yet still done properly and with the right materials. That is not breaking the GM warranty. It's sad that so many people think they have to take their vehicle to the dealership and only to the dealership to keep their warranty proper....
I was able to get my oil/filter changed yesterday, using my provided Amsoil 5W-30 Full Synthetic Oil, and a Wix XP oil filter.
I like to use the best in regard to the care and maintenance of my vehicles, especially w/the care of the turbo.
Some will dispute this, but oh well. 🤷‍♂️
Over the holiday, I did well over a thousand miles, including off-road, w/over 5040 miles now on the engine.
I bought the truck used w/just 3200 miles on it.
The Chevy Service Manger gave me all kinds of bull about the fact that they can only install GM products, which I've never had issues w/other product dealers, but finally conceded when I came back, and even then, only w/the oil, stipulating that they are not responsible if anything should happen using non-GM products. 🙄
I left my Wix XP oil filter w/my oil, and they installed it w/the oil.
It gets very hot where I'm located too, reaching well over 100 F during the summer months here in Eastern California.
This is another bot thread! I'll bet dollars to donuts this MFer couldn't figure out which way the drain plug twists to drop the oil. He damn sure couldn't post a video showing him doing it.
Work slowed so I Just finished deep cleaning the ENTIRE air intake system including....the throttle body. Spraying, scrubbing and rinsing.....Completely degreased the engine and scrubbed and sprayed everything down... Then changed both filters, 6-6.5 quarts of Pennzoil ultimate Platinum 0W-40/ 2 quarts Lucas synthetic stabilizer and still have to finish the coolant flush, new spark plugs,.... I chose the Bosch double iridium and the trans-filter change out And finally an AC system purge and refill. 48,540K now and still runs like a raped ape.bVery blessed and happy with my purchase 👍
Sounds like a proper tune up!
Where did you have you oil/filter changed? One of those quick lub places?
I've heard horror stories when it comes to those places, from using the wrong oil filter, to the wrong oil type, where automatic transmission oil was used in the engine.
Why the 0W-40 oil in your engine vs. say 5W-30?
I do 99% of my own maintenance. I have done every oil change on the truck since I drove it off the lot @8 miles. I did however get the free one at the dealership within the first 12 months. Even then, I brought the Lucas to the dealership and had them put it in. I change oil every 2.5k regardless and always use high quality oil and filters and always Lucas synthetic stabilizer EVERY time.
After watching a test using Lucas and 3 other brand treatments and seeing the engine with Lucas run an additional 30-40 minutes without oil after the others had already blown up, I use Lucas in every engine I have had.... cars, truck, motorcycle and even generators.
I also run a oil catch can system since around 2k miles. It's dumbfounding how much oil and garbage these engines will put back through the intake system if you don't have a catch can system. I own my truck outright so I try to protect and care for things best I can.
I use Pennzoil Ultra Platinum full synthetic and K&N oil filters. I have used mobil 1, but only one time. I prefer Pennzoil Ultra Platinum.... Out of all the brands of oil (including Amsoil) that Blake the motor oil geek tested..... it came out on top. I trust his science.
I also use the STP off-road package air filters. (STP is only brand I can find locally readily available that makes that style air filter.) I see some guys use those oiled K&N filters and to me it's like throwing sandpaper and dirt in your engine... The off-road package air filters have an extra layer for the super fine dusty desert atmosphere I live in.
The service rep I work with is pretty good and doesn't sweat the small stuff. He's the one that told me just keep all my receipts and dates and mileages of all the maintenance done.... So to keep the GM 150K warranty protected.
I'm going to have a local trusted honest mechanic I know do the plugs coolant and the trans filter. (I've already purchased all the materials I'm just bringing them to him) I did a trans flush at just over 30k miles at the dealership and got raped for $1300, but want a new filter before 50k. I could do it all myself, but for the price I'm paying.... $200 for the coolant flush and plugs.... and $200 for the trans filter it's an acceptable trade off to me climbing up into the engine bay for the plugs. I'm too old I don't bend like I used to 🤣
As far as the oil viscosity... My service rep told me they do check the viscosity if the engine blows and if I'm not running 0W -40, I could have friction with GM. Besides the climate I live in that's fine.... If it was a colder climate, I would probably take a chance and use a slightly different oil. I have had the Range DFM module for almost as long as I have owned the truck and in my personal opinion, that is 3/4 the battle with the 6.2l issues.
Yep...even the wife said she could feel the difference after cleaning the throttle body. It wasn't too bad, just mainly around the outside ring and on the edges of the intake swivel plate was where most of the build up was. Keeping the air intake system clean makes a huge difference compared to some of the things I've seen other fellas do. I can't even begin to imagine how horrible things would be if I ran a cold air intake 🤣
I too use to do all my own work, but I've gotten a little too old to do it now-a-days. 😞
Forgot to mention ...also cleaned the absolutely FILTHY MAF Sensor....big difference clean 👍
