OEM Wheels + 1.5" Wheel Spacer Pic Request
You're Truck looks awesome. Do you have any rubbing with that set-up ?
Very little in reverse at full lock mostly, but I still did some trimming. Would be fine for a mall crawler but i use my truck quite a bit off-road so i gave it clearance. I followed the suggestions on this thread trimming except i didnt cut a step into the lower bumper section, i made a smooth transition from top to bottom. I didnt like the idea of cutting up a new truck but the parts he cut are easily replaced for about $50 if i ever need to revert back to stock.
Thanks
Luckily the truck came with a few "perks":
  • Bedrug (who DF puts carpet in a bed -- especially $500 carpet)
@USMCsilver I do!
I am in the IT industry, so I oftentimes pick up IT equipment. The bedrug is awesome for that kind of thing.
I'm also rough on my bedrug. My previous truck had a 12-year old bedrug and it looks like new since day one that has seen lots of blood, lots of oil, lots of stones, lots of wood and it pressure washes off easily. I use a floor vacuum to vac the dirt out.
Nice... which can is that?
Thanks. That's a SilencerCo Omega 300 with anchor brake and ASR mount.
@USMCsilver I do!
Well, that's very promising news.
Mine is a little different, as it even covers the sides of the bed.
1.5 bora spacers stock wheels stock tire size 275/70r18
Thanks for the help, y'all.
I got them installed last week; I just didn't wanna mess with it. I also had some debadging done and had 'em throw the Range module on while they were there.
I installed 1.5" spacers at 500 miles or so. No need to cut the studs using the stock wheels. The spacers made a huge difference in stance but the stock tires are still way too small.
What brand of wheel Spacer did you use?
Just for giggles, here is a pic of my truck. I'm running 1 1/4"s on the front and 1 1/2"s on the rear. The front track is slightly wider than the rear from the factory so that's why I set mine up this way. I'm in architectural / engineering design and extremely OCD when it comes to dimensional discrepancies that no one else on the face of the planet would ever notice🤣View attachment 18651View attachment 18652
what brand did you install for the wheel spacers?
Fairly plug-n-play. One of the forum vendors has the kit available. There wasn’t a “kit” available when I did mine. I bought the brackets from a Facebook post and the lights off Amazon. I preferred the white lights because they matched the white DRLs.
And they are very inexpensive. 6 lights, 6 brackets, connector and fuse for only $94..... OR..... 4 lights, 4 brackets, connector and fuse for only $69. You can't beat the price for this upgrade.
Much nicer, cause the lights are subtle when on like an accent shoukd be and not so big in the grill.
