- Oct 3, 2022
- 1,147
- 2,990
Featured
- #1
I put on board air and Airlifter airbags on my ZR2. I had air on my Duramax and used it pretty often, so I wanted it on my ZR2. Wasn't sure if it would fit on the ZR2, but found some tanks on Amazon that fit great between the cab body and frame. Mounted dual compressors on the inside of the frame rail on the passenger side.
I did dual tanks and dual compressor. Had a single 5 gallon tank on my Duramax with a single compressor. Worked well for the most part. If you had to fill multiple tires or were running tools you would have to wait on the air to build up sometimes though.
I ended up adding air bags because my tractor squatted my truck to much. Originally wasn't planning on putting bags on this truck. I put daystar cradles on the bottom so the bags wouldn't limit the suspension travel.
