powoq
🌟 Forum Vendor
- Jun 24, 2026
- 24
- 16
- Moderator
- #1
Hey everyone,
Our team finished a dedicated bed and tailgate mat for 2019-2026 Silverado and Sierra 1500 (5.8-ft beds). It won't fit MultiPro tailgates, drop-in liners, or 1500 LD models.
Made from heavy-duty, odorless TPE, the mat measures a solid 7mm in overall thickness. The material is soft and pliable, giving the truck bed real shock absorption when loading heavy tools or gear. Across the surface, a dense pattern of raised texture studs provides reliable grip to keep coolers, boxes, and cargo from sliding around.
A big advantage of the one-piece layout is that it bridges the gap between the bed and tailgate. This keeps gravel, dirt, and small hardware from dropping into the hinge seam. For installation, the tailgate section secures cleanly using pre-applied automotive tape and screws directly into factory holes.
The mat trims easily with scissors. You can easily cut around aftermarket bed accessories, toolboxes, or separate the tailgate piece entirely depending on your layout. When dirty, it simply hoses off and dries quickly.
If you're looking to protect your truck bed, you can check it out here: https://bit.ly/4C72rHc
Feel free to use code POWOQ10 at checkout for 10% OFF your first order.
We'd love to have you in our owner community — we regularly share install tips, truck builds, and exclusive member discounts.
