Sterling Gray 1500
ZR2BIZON
Colorado
There's a Sterling gray Bison at the dealer I buy from. Thought I'd post some pics since there's none for 1500's
I noticed the 4wd buttons were sitting wrong.
Also snapped one of a white LTZ with the blackout option
Thanks @ZR2BIZON, yeah, those look broke to me, guess someone pushed too hard and busted out the back support maybe? And it isn't just the buttons, the dial is also way recessed in the hole in the dash, that is definitely broken. Sometimes when I get out my knee will hit one of the dials, probably the Mode/Tow Haul dial, and I am always afraid I will break it, so I try to be careful. I probably should set the "Exit" switch and use it to lift the steering wheel and lower the seat and slide it back the last little bit to get away from them.
Mine were like that too, and I think I read at least one other member had the same issue. A gentle push to the side got mine to click into place and they’ve been great ever since. I think something on the assembly line is slightly out of tolerance.
My appologies Sire. I've been cerebral flatulencing all day.
View attachment 11776View attachment 11777
Mine were like that on both rigs. It's a feature not a flaw.
I reached up behind the dash on the 1500 and they spapped into place with a little push from behind. 2500HD did not work, they seemed solid. I think I managed to make them worse by continuing to try to manipulate them. Parking brake button is crooked as a dogs hind leg now.
