The big question is. . . Are you able to shift into neutral if the turd bricks itselfColumn shift, but if it's electric and lightweight like I recently seen, then it'll be shit. I'd break it off the first week.
It frees up the center console and you dont have goofy cup holders.
Probably not since it’s still just an electronic switch just in the form of a column shifterThe big question is. . . Are you able to shift into neutral if the turd bricks itself
They have a put a box end wrench in the missing glove box if you can get under it to access the shift cable into the transmission.The big question is. . . Are you able to shift into neutral if the turd bricks itself
Amazon link pleaseThey have a put a box end wrench in the missing glove box if you can get under it to access the shift cable into the transmission.
It felt mechanical to me.Are the current crop of 2500s electric shift or mechanical?
There's shift linkage going into the transmission to engage from park. The transmission control module (TCM) does the gear shifting L1-L10.Are the current crop of 2500s electric shift or mechanical?
If it's like the electronic column shifter in some of their other vehicles, it'll be shit. Not something you're going to want to grab if you're off road and you need to jump into neutral or reverse.Column shift, but if it's electric and lightweight like I recently seen, then it'll be shit. I'd break it off the first week.
I can't recall if I felt that in a new Tahoe or if it was that EV Trailboss I was in. I have no idea how the EVs work, but generally speaking that seemed like a decent looking rig and sat big!If it's like the electronic column shifter in some of their other vehicles, it'll be shit. Not something you're going to want to grab if you're off road and you need to jump into neutral or reverse.
I believe I read this isn’t the same 6.6 that’s currently in the HDs, it’s a “new” engine for the 1500’s - I can’t find the link where I read that, someone closer can confirm or correct me here.I am wanting to hear how much tire you can get in to the wheel wells now that it starts stock with 35s. Will Peak and others be ready with aftermarket lift/suspension kits, Borla exhaust upgrades, Method wheels, all the cool stuff. BTW, I assume the 6.6L is the same tried and true 6.6L Chevy currently has. Damn sure will want a Cold Air Intake FIRST thing!
That's correct! This new generation motor has been discussed for a long time. It has its own unique motor code.I believe I read this isn’t the same 6.6 that’s currently in the HDs, it’s a “new” engine for the 1500’s - I can’t find the link where I read that, someone closer can confirm or correct me here.
Thanks for confirming - and validates I wasn’t dreamingThat's correct! This new generation motor has been discussed for a long time. It has its own unique motor code.
The biggest question is where will it be built and what QC will be done to ensure the parts are built correctly? They still haven't demonstrated the ability to build 6.2Ls in spite of knowing what the issues are with bad parts and questionable assembly.
Fucking great, no dipstick needed cause GM can build great motors, develop precision software with no glitches, and procure top tier electronics from Bangladesh to ensure your oil is just fine!![]()
V8-Powered 2027 Chevrolet Silverado 1500 and 2027 GMC Sierra 1500 Don't Have an Engine Oil Dipstick
On the bright side, the all-new Silverado and Sierra half-ton pickups keep a physical dipstick for the four-cylinder turbo gasser and the Duramaxwww.autoevolution.com
