Depending on how long you’ve had your ZR2 and unless you have a subscription, it may be that your trial period has expired. Certain features such as XM and google assistant are not functional without one.I can't access my XM radio since I loaded my Apple carplay. Also my google assistant now shows that it can't connect. I didn't have these issues before loading the carplay. Any ideas? Thanks
In that case you can try a factory reset. If that doesn’t fix the issue, I would haul ass to the dealership and drop that problem in their court. Technology truly is a blessing and a curseI've only had it 2 days
If I remember correctly, Google assistant doesn't work with CarPlay. As for the XM issue. Have you selected the music note icon on the screen? All sources of music outside of CarPlay should show up there.
