- Jan 1, 2023
- 3,614
- 7,673
Featured
- #21
Looks great my friend...I love the black wheels.Before & After
I wish Corsa would finish the dev work on their system for our trucks... it's been saying "in development" for a year. Interesting you had drone from a Corsa system, I've had them on several vehicles and never had an issue with cabin drone.Finally got the Borla 400844 Crate muffler installed! The ZR2 sounds how it should have from the factory.
In my experience, the cabin drone is slightly more noticeable than the Corsa cat back system on my previous truck (5.3L Sierra), and Wife's Yukon (6.2L), but absolutely worth the shit eating grin.
LP definitely agree. Corsa is hard to call "drone" because there really isn't anything there. When comparing to stock, it's just louder (dB) not necessarily noise pollution. It works beautifully, and meticulously when cruising the highway.I wish Corsa would finish the dev work on their system for our trucks... it's been saying "in development" for a year. Interesting you had drone from a Corsa system, I've had them on several vehicles and never had an issue with cabin drone.
Beautiful truck by the way!
Any rub on the wheel setup?Another Storm coming right now. I love this thing.
I have only noticed when I am reversing into my driveway (various angles/small elevation changes) and wheel is full lock left, a rub.Any rub on the wheel setup?
Nice work there buddy, giving me plenty of ideas for my delivery in June.Before & After
305/45R22 Nitro Recon Grappler AT's [218410]Nice work there buddy, giving me plenty of ideas for my delivery in June.
Whats the specs on those wheels?
I think a -18 offset is approximately equivalent to 1.5 inch spacers on these stock rims. Don't forget, rim and tire width affect the amount of poke you get from wheel well. Stock rim width is 8.5, alot of rims can be 9, 9.5, or even 10 inch.So here I am staring at your build again! lol... One last question: Is the offset on those wheels the same as OEM? I don't see what they are calling out on the wheel site. I guess I'm asking what is the offset on the ones you got? And, (ok stupid question) do you know if you could order the offset to compensate not using the 1.5 spacer? And did you re-use the Chevy Bow Tie center caps or order those somewhere?
Thinking about pulling the trigger on this set up!
Wheels: $595 each
Tires: $438 each
Thanks for your input, appreciated!
Factory spec indicates they are 1.10" or 28mm positive offset. I like the more aggressive look of a negative stance on trucks, and therefore used the spacer at 1.5". I'm not big on running spacers, but I'm not racing, or doing Baja... ran them for 13 months on my last truck, 0 issues.So here I am staring at your build again! lol... One last question: Is the offset on those wheels the same as OEM? I don't see what they are calling out on the wheel site. I guess I'm asking what is the offset on the ones you got? And, (ok stupid question) do you know if you could order the offset to compensate not using the 1.5 spacer? And did you re-use the Chevy Bow Tie center caps or order those somewhere?
Wheels: $595 each
Tires: $438 each
