The_Q
- May 20, 2022
- 555
- 1,416
I have the evcX Throttle ControllerWhich ultimate9 do you own? I’m very interested in buying one
Many thanks!!You want the evcx model
evcX Throttle Controller to suit CHEVROLET SILVERADO 2019 - ON (4th Gen)
EVC evolved, EXPLORE the power of your vehicle with the wireless-enabled evcX Throttle Controller. Features: • App controlled• Ultimate9 TC app - iOS/Android compatible• 8 Driving modes, 32 levels of adjustability• Lock Mode• 10-minute installation, 100% plug & play• Removable user interface...www.ultimate9.co
thanks!! let’s say the throttle is locked and they remove the cable that connects to the throttle and they plug back in the OEM connector to the throttle. Will it unlock it or does the memory stay saved to the computer?I have the evcX Throttle Controller
If they remove the evcX controller, the part that plugs into the throttle pedal and plug the stock connector back in I’m almost positive the throttle would respond like stock. But they’d have to know where to look. Also if the battery isn’t disconnected during installation and uninstalling the truck WILL throw codes and could cause drive ability issues.thanks!! let’s say the throttle is locked and they remove the cable that connects to the throttle and they plug back in the OEM connector to the throttle. Will it unlock it or does the memory stay saved to the computer?
I see. So you hide your cable that connects to the controller each time you disconnect the controller and leave the truck? Ah good to know thanks for the heads up with the installation. Each time you disconnect the controller you need to disconnect the battery too?If they remove the evcX controller, the part that plugs into the throttle pedal and plug the stock connector back in I’m almost positive the throttle would respond like stock. But they’d have to know where to look. Also if the battery isn’t disconnected during installation and uninstalling the truck WILL throw codes and could cause drive ability issues.
Once installed you don’t need the cable or controller box. The wire harness with its inline controller is Bluetooth. Once paired you can control the throttle from your phone.I see. So you hide your cable that connects to the controller each time you disconnect the controller and leave the truck? Ah good to know thanks for the heads up with the installation. Each time you disconnect the controller you need to disconnect the battery too?
Which steering wheel club do you use?I use the throttle lock on the Ultimate9 throttle controller. They can start it, but they’ll get no throttle response. Also use a steering wheel club. Living a few minutes from the Mexico border, these things get stolen all the time.
I bought an inexpensive one off Amazon.Which steering wheel club do you use?
Got it thanks for the explanation! Have you had any issues with theft or signs of attempted theft after you installed the evcX?Once installed you don’t need the cable or controller box. The wire harness with its inline controller is Bluetooth. Once paired you can control the throttle from your phone.
Just to clarify, the evcX comes with a control box, wire harness that plugs in between the throttle and the throttle harness and a cable to connect the throttle box to the controller.
Okay thank you for sharing!
100%. If the unit is removed and the stock connect is plugged back into the throttle, it is back to stock. As was stated, a thief would have to know what to do to bypass the U9 security.If they remove the evcX controller, the part that plugs into the throttle pedal and plug the stock connector back in I’m almost positive the throttle would respond like stock. But they’d have to know where to look. Also if the battery isn’t disconnected during installation and uninstalling the truck WILL throw codes and could cause drive ability issues.
Thankfully no. I live about 15 miles from the southern border. Vehicle theft here is very high.Got it thanks for the explanation! Have you had any issues with theft or signs of attempted theft after you installed the evcX?
That’s really amazing, glad you haven’t especially being that close to the border! Well I appreciate all your help!Thankfully no. I live about 15 miles from the southern border. Vehicle theft here is very high.
That is the beauty about the U9...you don't have to have the control head plugged in at all as the brain is in the connection at the pedal. No one would ever think to look if they can't find a control head like on a Pedal Commander, etc.Chiming in here, I also have the evcX (per recommends here with these guys) and only plugged in the controller to pair for bluetooth. After that, I disconnected and hid the wire, no need for the controller since I use my phone. I like having the module for the performance along with the security feature. Can turn it down as well for valet, don't need those clowns driving over a Porsche by accident lol. Very pleased with it and we have issues with dirty thieves key fob hacking around here. They may start it, but by the grace of baby Jesus, they won't get far idling down the street, me in tow.
