Brake Job ?
Jul 17, 2023
156
236
My pad life indicator is telling me I have around 45% of pad life remaining. My question is, Is the dealer the only one that can reset the computer once the pads are replaced or can an independent shop/mechanic/myself do it ? I've always done my own brake jobs until I purchased this truck. I just don't want the truck throwing codes as I've read in other places. Thank you !
I believe you can do it through the gauge cluster.
That's pretty good. I'm sort of the mindset to change them early and not run them down too low where pad can just get brittle and break. Then you're doing rotors too.
My 2005 Duramax had the original brake pads when I sold it after 10 years and 150k miles. They still looked 65%. That was with towing and city traffic. I don't brake hard, but that was crazy. Current Duramax has 84k and they look great. Not sure why all brakes can be that good.
i had a Brake Sensor message come up for the last week, took it to the dealer today and said need new pads and rotors, pads were down to 5%
Sounds sketchy for rears with that many miles? Front should wear faster.
My wife's last Tahoe ate front brakes at 35k, didn't seem to matter when I bought high dollar aftermarket pads. I think they are under sized.
actually ive never gone through brakes that quickly, the dealer said they had a ridge of rust on them and when that happens they wear fast...fronts still have 60% i find it odd
Coming from the rust belt if you don't service your brakes especially the rears they will get sticky and seize up. I always service mine after the salt is off the roads in the spring and usually before winter starts.
Found your replacements:
So, at $5395.00 these are about the same price as pads and having the rotors turned at the dealer 🤣
GM makes a big brake kit by Brembo and it's much less then the one shown..
FYI I do performance and have them on all my GM products!
The best thing is that they come with supported hardware and the GT series don't
You will have to retro the wear indicator.
Does the kit from GM fit our stock wheels?
