Crankcase Breather Side Catch Can
Oct 24, 2023
43
63
Throwing this out there to see if anyone has any thoughts on adding a catch can to the crankcase breather side as well? (Passenger side)
I already have the PCV side running a catch can. I pulled the factory plastic line off the pass side just to check it, and I have a little oil like residue in the hose.
My two cents for what it’s worth. The passenger side is the positive pressure side which goes into the engine as it is fed from the air intake. The driver side is the return from the engine which will have the oil in it which is why I think it only needs to be on the driver side.
Thank you!
