- Dec 17, 2022
- 48
- 197
- Thread starter
- #21
i might have a solution although like you said might be hard to incorporate.Sexy!!
The Cadillac mufflers would be my choice, but may be harder to incorporate.
You won't go wrong with Corsa either, out of the choices of off the shelf mufflers, they would be least likely to drone.
Keep in mind mufflers used outside of a designed system will sometimes have undesirable characteristics, ie drone.
Good luck, we're all counting on you.
My idea is to mount both stock mufflers vertically in the red area to clear the drive shaft and tuck it much closer to the cab for ground clearance would be nice if I can get my hands on the stock muffler dimensions to test it out with cardboard before pulling the trigger
