Exhaust clearance to DSSV’s
So still loving my exhaust but I had a question. Is this clearance okay? I don’t really off-road but haul stuff occasionally. This is the drivers side btw. I know the stock even came kinda close.
  • #2
Here is two more shots
Heat is not a shocks friend. That second pic looks much better
Thank you! I feel much better about it. You think clearance is good now?
I think it would be fine. You could always check the temp on the shock after the truck has been running for a bit. The stock pipe is also pretty close. But not as close as that first picture.
Make sure you also have plenty of clearance between the spare tire heat shield and exhaust. My Borla was vibrating so much at low RPM it was contacting the heat shield.
