- Feb 21, 2023
- 5,551
- 13,237
I ordered my first GM truck ever, a 2500 HD ZR2 Bison. I wasnt sure what to expect and it's been a little confusing process. Here is some information I found on the nomenclature used during build process from GM authority and it helps me understand it better.
Allocations – The number of a particular vehicle model a dealer is assigned by GM.
Consensus – The planning and forecasting of vehicles between the dealer and GM. A quantity of vehicles that a dealer requests for a given production period from GM. Based on GM data and constraints they may or may not receive the amount requested.
Constraints – Items that are unavailable for ordering due to plant or supplier issues. This could be a certain option or an entire model of vehicle.
Event code – The status that indicates a certain point in the life cycle of a vechicle.
GM OrderWORKBENCH – The website used for ordering GM vehicles.
Final Allocation by Week Report – This report shows a dealer’s final allocation quantities for the specified production period.
Pass 1 – The preliminary pass of the vehicle order process which looks at only the quantity of preliminary orders that equals the lower of a dealer’s allocation quantity and desired quantity.
PDI – Pre-Delivery Inspection
Preferenced – Order has been sent to one of the GM production management systems
Preliminary order – A vehicle order that has been submitted to GM through the OrderWORKBENCH system. It would have successfully gone through Pass One. These orders have an Event Code of 1100 (Preliminary Order Accepted)
Priority number – Indicates the dealer’s preference for the placement of a preliminary order. The lower the number the higher the priority. A sold order defaults to a priority of 1, stock orders default to a priority of 99. Priority 0 means that the dealer does not want GM to place the order. The dealer can change these numbers as needed.
Sold order – A preliminary order that is placed for a customer
TPP – Target Production Period – The date range used in order to define the effective period for a marketing or allocation constraint. Also the period when a specified number of vehicles is scheduled to be produced, typically a 1-2 week period.
TPW – Target Production Week – The week in which the specified vehicle is expected to be built.
How it all works:
Consensus:
Dealer puts in for requested quantities of different model groups
Dealer allocation quantity changes from “production consensus” to “final allocation” after GM resolves any variances between the approved production volumes and production consensus quantities (needs some verification on the days referenced below)
Final Allocation by Week Report is released mid month on Wednesday
Report shows allocations by week for 2 week timeframe
Allocations are assigned on Thursday each week
Dealers have until the following Tuesday to resolve constraint issues before orders are pulled
Ordering:
Order is configured in GM OrderWORKBENCH
Customer information is assigned to order
Order is checked for constraints
Order number is generated
By default the sold order is given priority number of 1
After consensus and dealer receives allocation they can apply it to an order
If there are no constraints it will be preferenced
If no action is taken the system will pull the lowest priority number order (1-99)
If multiple orders are at the same priority number it will pull the oldest order first (need verification)
As long as there are no constraints it will be preferenced
If there are constraints the dealer would have to either re-configure the order or allow a non-constrained order through
Order is eventually run through Pass 2, 3 and possibly a 4th optional one that can be used and GM may also use
How it all works:
Consensus:
Ordering:
