GMPP, Borla S-Type exhaust modded with tips!
Diesel328
So, I like the look of polished SS or chrome tips. I appreciate the tucked up exhaust of the ZR2 and wanted to keep that but just add a little bling! I found these on Amazon and decided to give them a shot. For 15 bucks a piece why not.
I tried to weld them on but the ss is just too thin. So I went with a 2.75 in band clamp and it turned out pretty good.
Perfect ! do you have a link to amazon ?
If you look inside the tip there is an insert that you can move back and forth a little bit. I removed that and the 3 screw clamps. The tip should slide right over the pipe. I then used a band clamp to hold it on.
Tips look great, I need to find them in black or sand these down and paint with high temp paint..
