Knocking from rear end
My 2022 has a knocking sound coming from the rear end, I've drained the rear differential and didn't see anything out od the ordinary. I took it to a mechanic he couldn't find anyrhing he thinks it may be the clutch in the rear differential. I took it to the dealership and theh said it's my leafsprings. It only makes the noise when im turning slow and it seems to be with a full revolution of my driveshaft. Also if I press the breaks and gas it for a burnout it also does it.. ive been riding her a little harder then normal (italian tune up) to see if she will expose the problem.. we are all a little stumped right now.. anyone have any experience with this issue
Try squinting WD40 where the rear axle bolts to the leaf springs and drive it for a bit. If the sound stops its probably the rubber pads between the springs and axle. I think GM has issued a service advisory for this and there are a couple of post on here about it.
If what @geddyflea suggested doesn't solve the problem. Check the bolts on the leafsprings closest to the cab. Mine were loose and I was getting a clunking similar to what you're describing.
Agree with above but how about this. If you say it happens on slow turns, what about it being the rear diff internal? Try locking the rear diff and drive it. Maybe on dirt to keep tension off it for slippage. The braking/acceleration seems to be leaf spring bolts but it still may be internal. Not sure of you have lift blocks in the back? Spitballin
