mass airflow sensor
craneguy
Monessen PA
when installing a cold air intake is it beneficial to also upgrade the mass airflow sensor, heard that the stock sensor may not be up to par with the extra airflow what are your thoughts ?
Install the " Air Raid junior system" system that Security Guy installed. It's on here under CAI threads.
The stock sensor has plenty of range for a simple CAI. It’s reused in supercharged applications that move much more air.
It is critical however that you disconnect the battery and wipe the fuel tables. The truck will need to relearn short and long term fuel trims.
During the learning period fuel mileage will suffer and eventually improve to normal or possibility of a slight improvement.
Crushed it. Absolutely pure facts. Nicely done.
