Older ZR2 owner wanting new tires for his ‘22 ZR2 - need help
I’ve ran Toyo AT3’s and Nitto Recon in the past both smooth and quiet compared to stock Goodyear
Which tires are you currently running on? Are they the stock size 275/70R18’s? Trying to find out if 285’s will fit without any rubbing or added spacers.
Still running stock tires till they wear out. Probably will be going with nitto g3 b/c of good wet grip on the boat ramp. A 285/70-18 on stock wheel will work without issues. A 285/75-18 with less aggressive tread will work with a stock wheel but will rub liner in full reverse lock.
