Smaller Antennae Recommendation
Anyone have a recommendation to replace the am/fm antennae with something smaller. It seems out of place these days. Thank you
The Ronin one is what I like, however they all work decent enough especially if you don’t use AM/FM.
I have this one and it works great! Looks factory but doesn’t hit the top of the garage.
AntennaMastsRus - 16 Inch Black Antenna is Compatible with Chevrolet Silverado 1500 (2006-2022) - Spiral Wind Noise Cancellation - Spring Steel Construction
https://a.co/d/blMuNGi
I swapped out the factory Wizard Staff in the dealer lot.
It’s still a semi-flexible piece. So it won’t impale you or more realistically be snapped off.
Swapped mine for this 4in one. Reception is still pretty solid around town other than a few heavily trees streets. I also like the solid aluminum body do no need to remove if you use the occasional quick wash.
Maxracing Short Aluminum Antenna Compatible with Silverado 2007-2022(M7 Thread) https://a.co/d/f0rSD88
I have the Ronin .50 cal on mine but it is purely for aesthetics because I don't use my radio at all, only music from my phone...
I’ve had this alpha defense bullet antenna on my 2020 Sierra I’m trading in when my 23 ZR2 gets built and here (long wait lol) in the 2 years I’ve had it on the truck there is no issues with it affecting the radio even though I don’t listen to it much either. Here is the link:
I have a Stubby antenna-works great! Used it on my 2020 TB, and installed it on my ZR2. I think Amazon sells them.
