whos running a drama free 33 set up
And they’re right, different brands with a same size are diff dimensions. Add in rim width too lol
Put on what you want and clean up what’s needed. Unless you have someone that can mount a bunch diff tires with diff offsets, too much work!
Why anyone would want to run a shorter tire than stock is beyond me.
Factory is 33.3 a “33x12.50” is 32.5. Way too small.
Actually every tire is a bit different. I have Atturo Trail Blade MTS 33x12.50r18 on my truck. The actual size is 33.1 inches. Plus, before I mounted them, I stood them next to the stock tires on my truck and with the brand new tread on the tire the Atturo's were actually about 1.5 inches taller than the stock tires. So, even though it lists the stock tire as being 33.3 inches, the actual size is a good bit smaller than that.
I run 33 X 12.50 X 20 with Nitto Recon Grapplers on 4Play Wheels (20 x 10 with an -18mm offset). NO issues on normal driving and maneuvering. Only on very tight turns do they just slightly rub. I love the stance, not too wide for me but aggressive enough to not be stock.
Looks good!
Oh hell, just put 44's on
Just finishing my 14 ft lift today.....these 350's are going on tomorrow. Just got an update photo from the transport driver to make sure they will be here on time!!! 😁😁😁.
sure hope someone yanked the strap and uttered "she aint goin no-where"...or thats an accident waiting to happen !!! :LOL::LOL::LOL:
hey all, new 22 ZR2 6.2 owner. so the wheel and tires are high on the list to change. Ive read 35s are the desired go to but thy dont seem to be something simple. Im not looking to change up the suspension yet. not even sure if im going to or how far down the road. My trailboss had 33x12.5 r20 with an aggressive stance. about 1 inch of poke. So can i run the same set up this truck with absolutely no issues. Or what are the similar set ups guys are running. thanks all
Method 707's (18X9) with 0 offset and stock size Terra Grappler G3's put on yesterday. I had 1.25" spacers but there is definitely a lot less NVH with these wheels vs the spacers. I had the G3's on with the spacers as well but now the ride is much improved and feels like stock again.
