whos running a drama free 33 set up
And they’re right, different brands with a same size are diff dimensions. Add in rim width too lol
Put on what you want and clean up what’s needed. Unless you have someone that can mount a bunch diff tires with diff offsets, too much work!
Why anyone would want to run a shorter tire than stock is beyond me.
Factory is 33.3 a “33x12.50” is 32.5. Way too small.
Actually every tire is a bit different. I have Atturo Trail Blade MTS 33x12.50r18 on my truck. The actual size is 33.1 inches. Plus, before I mounted them, I stood them next to the stock tires on my truck and with the brand new tread on the tire the Atturo's were actually about 1.5 inches taller than the stock tires. So, even though it lists the stock tire as being 33.3 inches, the actual size is a good bit smaller than that.
