2022 Reduced power warning
upon starting the vehicle, , immediately get a “reduced power warning” message on the dash and the truck was idling roughly and no power on steppping on the gas, nothing. Started stopped 6 times no change. Finally pulled some fuses including a 50amp off passenger side fuse panel and it cleared it, drove home with check engine light on. Pull power to the battery and it cleared the light. Anyone experience this? Or just lucky me.
Prior to this, had power windows issues and vehicle collision alert went off last software update might have remedied windows, not sure yet
Yeah there are some other reports like this. Some have software issues, while other have hard parts failing like the fuel pump control module. Best to get it to the dealer for proper diagnosis and service with significant issue.
I had the same problem. Took it to the dealership and the code came up contaminated fuel. Dealer recommended putting premium gas in as I was using 88 octane because it was way cheaper where I live. Haven’t had a problem since. But it could have been some bad gas too.
I've run plenty of 87 in two 6.2L motors just to see how it worked. It worked just fine and no noticeable performance issues. I mostly run 91, but if you had issues, it wasn't the octane rating.
