6.2 Recall Letter
I'm gathering up resources and getting a hold of a factory rep.
I would either show the dumb ass service advisor your recall letter or simply go to a different dealer. We all get the extended coverage for this particular engine problem regardless of what these idiots say. Just keep in mind that the extended coverage only covers this particular problem regarding the out of spec crank and bearings contained in this recall. It is NOT A COMPLETE 10 YEAR/150000 MILE POWERTRAIN WARRANTY.
I got the same letter on my 22. It just turned 48,400 miles. Taking it in Monday for test. I'm sure it will probably pass as it should have blown up by now IMO. It's still running great. Let's see.
well my POS passed the Pico test but was denied the extended warranty. The service advisor (Ozark Chevrolet, Mo.) told me that the only ones to get the extended is the 2.7ltr diesel and it only gets 100,000mi . Looks like GM is on the take again.
Check your myChevrolet app. It shows up there.
Special Coverage N252494003
Forgot to mention that the dealer installed an update that will now flash a message if the truck is experiencing the dreaded P00016 code. It is supposed to display a message if this is occurring on the DIC so you can take your ass to the dealer quick...if you make it. :). It's part of the recall.
Interesting! It's like seeing tracer rounds over your head!
I brought my rig into this morning. I didn't think it was much of a deal to do the test. SA said it would take a good part of the day. Work order said ECM update......probably the P0016 monitoring system.
Mine took about 4 hours.
Mine took 5 hours with three updates for the ECM, infotainment and body control module. I also had my 30,000 mile service done.
Has anyone had their engine or know of anyone who've had their engine replaced under this deal? I'm pretty sure all of our engines have passed inspection unless the vehicle was brought in on a flatbed with a blown motor.
My SA said he recently had two trucks brought in with smoked motors. Theyve done several more in the past. Most are passing.
He said one of the guys truck flashed a SEL message on the DIC when he was on freeway. He shifted lanes and made it onto the off ramp lane and it completely stopped and he damn near got run over.........that's why there is a recall.......yee haw!
By the way did you do the transmission service? If so, how much?
I'm probably gonna do that on the Tahoe if it passes, but I don't think it will.
I did... If I'm not mistaken it was $399 for the transmission service
My guy said it was $275. But didn't clarify if that included the filter which is supposed to be every other time. I didn't think that was bad, cause that fluid is pretty expensive. There's no dipstick drain plug so it's PIA!
Service advisor just told me they fried my ecu doing the ecm update for the recall. "Trying to find another ecu". We'll see if they blame the Range DFM module cause I left it in. They've never said anything in the past and I always have shit on my rigs.
Wow! That really sucks. Good luck. Hope they can get a new ECU relatively quick.
GOOD GOOGLY MOOGLY😵‍💫🫨😵😫
So sorry to hear!!! When i took mine in to have the trans service and the collision system, lane assist, adaptive cruise and blind spot indicators.... They notated the paperwork saying it could possibly be my aftermarket wiring... I told them it was total BS because I disconnected everything before I even brought it to them. They did end up paying for three new camera modules, but that negative comment on the paperwork..... insinuating that it was my fault and not Chevy's genius engineering!
They had another ECU and pulled the range module and did the reprogramming. I'll be picking it up in the morning.
They did say the range DFM module contributed to the bricked ECU. But said they would warranty the part. I've always had a good relationship with the dealer and SA, so I suspect they went to bat for me here and I appreciate that.
I'm not so sure it did cause the issue, cause there's plenty of examples of them bricking during updates. Also I've had it in twice for other updates and told them it was installied. However, I will accept my share of the responsibility because I knew they were going to update the ECU cause he told me so when I checked it in. I should have reminded him it was in there. I also knew that Range recommends removing it for any work done using the OBD II port, which is basically everything nowadays. I should haver pulled it and played it safe. So I'll own it!
Also found out that the Tahoe will not require the ECU update. I guess its VIN specific. But I'll plan to remove it anyway cause it only takes a few minutes.......live and learn.
Reactions: KLA
