Driver seat bolster rubbing against side of center console.
Hi everyone, new 2025 1500 ZR2 owner here. So far I love the truck, my only issue is the driver side bolster rubs against the center console and squeaks anytime I move. I've adjusted seat height, and nothing helps. I noticed the passenger side doesnt touch the cneter console. Has anyone else noticed this? Is this common? Thanks for the help.
Is your seat base loose or shifted? Mine was loose and I had them replace the hardware kit and cinch it down again.
This has been an issue with the seat bases since the 2015 models, had it happen before on another rig too.
It doesnt feel loose. I'll definitely have them take a look. Thanks for the help.
It may not feel loose when you grab it, but you can sometimes feel it shift when your driving, especially turns and terrain.
Mine does this and rubbed the trim so much it’s tore it up. Soon as the wife. The seat also pops when taking corners and tight curves. Dealership ordered a seat frame and new trim. Soon as the wife can drive again they will be replacing it.
I have this issue; did not think much about it until I read this post. I might take it in after reading Byrds8's experience. Thanks
It will actually rub the clear off the trim. I just had mine replaced. I now have a microfiber cloth between the seat and console trim.
Shouldn’t have to have something added to keep it from getting damaged.
