Stock 23 wheel offset?
Can anyone tell me what the stock offset is on the 2023 ZR2 18" rims? I've seen numbers all the way from +12 to +28. Trying to determine if I want to go with 0 offset or -12.
TIA
+32mm, at least on the Bison. I'm running -12 Methods and and have a detailed post on the trimming required to get clearance for 295 tires.
Mine is 26 stock, have a set of Black Rhinos going on next week, 17’s - 8.5 with 0 offset.
This is the standard ZR2 and not the Bison. I think the consensus I've found is stock offset is +26. I want to stay with 18" rims and probably going up to a 285/70 since it looks like 285/75's won't fit without modifications which I don't want to do. With the added tire width and going with a 0mm offset I think that will work for me. Not sure if going to -12mm with that setup will rub or not.
I have standard ZR2, and someone on the oversize tire thread has the 0 offset which looked great, no rubbing. -12 with the width may rub
I had 0 offset wheels on my old truck, and that Black Rhino wheel in the picture does not look like a 0 offset wheel. It looks no different than the offset of a stock wheel. Sometimes it's hard to tell from a picture.
Probably a lot of material on the back side of the hub to get the spokes toward the edge of the wheel.
Yeah, maybe it does. But it looks and awful lot like a stock offset wheel, not a 0 offset wheel. Would have to see the back side of the wheel to see if the spokes and mounting point are centered to make it a 0 offset wheel.
