Stock 23 wheel offset?
Can anyone tell me what the stock offset is on the 2023 ZR2 18" rims? I've seen numbers all the way from +12 to +28. Trying to determine if I want to go with 0 offset or -12.
TIA
+32mm, at least on the Bison. I'm running -12 Methods and and have a detailed post on the trimming required to get clearance for 295 tires.
Mine is 26 stock, have a set of Black Rhinos going on next week, 17’s - 8.5 with 0 offset.
This is the standard ZR2 and not the Bison. I think the consensus I've found is stock offset is +26. I want to stay with 18" rims and probably going up to a 285/70 since it looks like 285/75's won't fit without modifications which I don't want to do. With the added tire width and going with a 0mm offset I think that will work for me. Not sure if going to -12mm with that setup will rub or not.
I have standard ZR2, and someone on the oversize tire thread has the 0 offset which looked great, no rubbing. -12 with the width may rub
I had 0 offset wheels on my old truck, and that Black Rhino wheel in the picture does not look like a 0 offset wheel. It looks no different than the offset of a stock wheel. Sometimes it's hard to tell from a picture.
Came direct from rhino and my son in law ordered them. Says 0 offset on the sticker for each. Should be fine
Probably a lot of material on the back side of the hub to get the spokes toward the edge of the wheel.
Yeah, maybe it does. But it looks and awful lot like a stock offset wheel, not a 0 offset wheel. Would have to see the back side of the wheel to see if the spokes and mounting point are centered to make it a 0 offset wheel.
Yep, like I said, some come with 20mm of aluminum on the back side of the hub to get the desired look and offset.
Are we good to move on now, 0 offset. 😆
Nobody ever stopped you. This is a public forum. People give their opinions. If you don't want peoples opinions, then don't read them. But, for the record, it still doesn't look like 0 offset to me. But, as I said earlier, it's hard to tell from a picture. Like Axe said, there is a lot of material on the backside, so it very well may be 0 offset. Hard to tell from the pictures.
26. You can install 10mm hubcentrics and drop it to 16 and still run 295/70’s with not a hint of rubbing at stock height.
Was kidding brother, no sweat.
