Water Leak Through Sunroof
I’ve noticed when I go through the touch-free car wash water will sprinkle through the sunroof during the high speed rinse pass. It appears the pressure is forcing down the sunroof. I used this with all my current and past vehicles and never encountered this issue. I’m just wondering if this is common or worth bringing to the dealer.
The roofs are thin sheet metal and relatively unsupported. I have run my 1500 and 2500HD through touchless car washes with no sunroofs. I can here the roof vibrate and flex. It's especially bad with 2500HD cause it's only 4 inches from the nozzles.
If I can avoid sunroofs, I will for these reasons, plus I don't like using them anyway.
Agreed...I have NEVER used any of the sunroofs I've had and really don't want another. However, about 100% of the dealers always order them with a roof. I know I can special order and may go that route next...we'll see.
If you get vehicles with LTZ or above and all the options, they rarely don't have sunroof around here. I got lucky with my 1500 and Tahoe and neither one had them. Ordered my 2500HD without one.
I had a couple electronic issues with my two previous vehicles and couldn'tget them closed. One leak when drain tube came loose at firewall connection. I will admit, the loose drain tube could have been self inflicted cause I had pulled some wiring through that same area before.
Question. Possibly a stupid one. But one that needs to be asked none the less.
Is this water getting into the interior? Or you just see water getting past the seal into the drain system?
Sunroofs are designed to leak…. A little. It’s as designed if that’s the case.
they have drains too. never liked sunroofs
I actually love the additional light and nice weather running it open, I ordered both my zr2s with the option.
To each his own, whether you like them or use them, many trucks have them. To the OP - my truck does this as well. You feel it hit you, it’s not like running into the cab or anything. It’s odd, you can just feel the “overspray”, it’s not much but enough to catch your attention. I’ve had zero issues outside the car wash.
On mine, it’s not really a “leak” per se that’s running into the interior or the drain. It’s like the pressure is just slightly breaking the seal and a bit of “over spray” can be felt on your head. It’s very slight, I second guessed myself until my wife was like “did I feel a tiny bit of water?”
You nailed it…….it is overspray from the powerful rinse wash (Not really a leak)
i, too, like the light and use the sunroof quite often in the Spring and Fall. Just surprised it doesn’t have a stronger spring to keep it pushed up.
Absolutely love my moon/sun roof and use it daily! NEVER had any issues and I have a monthly subscription to GO Car Wash and have run mine through up to 3 times a week sometimes for almost a year. Never any issues.
I got in the truck this morning after a rainstorm and there is water dripping down the controls overhead. Soaked down the headliner pretty well and dripped below onto my phone and belongings. I love where it shows pretty heavy. I guess we'll see how much of an issue this is going to be.
There are lines that run from the roof down the a-pillar through the firewall to drain the water from the sunroof. If the line is disconnected, the water would drain into the roof/ headliner or behind the dash through settings your left foot area. Otherwise, it may be a loose seal around the perimeter of the sun roof.
Every car/suv I've had that had sunroofs leaked eventually. I never used them except when the kids asked for it, so I specifically ordered mine without and the salesman looked at me like I was crazy. Haven't missed it yet. Do love the sliding back window. Probably would like it even more if it slid all the way down like some Toyota's do.
