Really? With no modifications at all? I find that very hard to believe.Well since no one in the group could answer my question i was able to find the answer in another group and see pictures. Anyone with a Non Bison ZR2 HD can put 37's on with the no rubbing on factory wheels and height.
Pictures or it didn’t happen. Correct @securityguy ?Really? With no modifications at all? I find that very hard to believe.
Even with pics, I think some mods had to have been done. @AXE may know better.Pictures or it didn’t happen. Correct @securityguy ?
look up ZR2 HD 2500 Group on facebook. A few member had pictures that replied to my question. Don't really care if anyone believes it or not just trying to help answer a question. I know the Bison is able to fit them with no mods and the only difference is the bumper.Really? With no modifications at all? I find that very hard to believe.
i find it funny that the people that find it hard to believe don't even have a ZR2 HDReally? With no modifications at all? I find that very hard to believe.
I trust what @AXE says and no one elsei find it funny that the people that find it hard to believe don't even have a ZR2 HD
It came from the internet. After all the info in these forums about 37 inch tires.i find it funny that the people that find it hard to believe don't even have a ZR2 HD
as you can see in this video there is a clear difference in clearance from the tire and bumper between the two packages. From my reading and research both packages will accept 37's depending on what tire choice but the Bison does have more clearance. Hope this helps anyone trying to decide.I think the primary limitations is the clearance with the inside edge of the tire with the UCAs. On stock offset rims you'll get close to UCAs, especially if your tire has heavy shoulder lugs. If you go with a 0 or negative offset wheel, then you could get close to the wheel well liner when turning because you change the geometry of the tire by 1 inch in diameter and 1-1.5 inches further out. Always best to test fit one wheel/tire before you go whole hog wild and drop $5k to find out it rubs.
You can read post on 37s and see photos of UCA clearance. Others have posted pictures of their 37s. The Bison package makes no difference.
