- Feb 21, 2023
- 5,938
- 14,322
I put some Air Lift Super Duty 5000 air bags and Wireless One compressor on my rig today. It cost about $1350 for them shipped from RealTruck.com. I think Etrailer.com might be a little cheaper.
I did mine in the driveway and I did not drop the spare because that only helps if you have a lift, so you have head clearance. I chocked up the front wheels and jacked up the truck under the reciever so the suspension was fully extended. Once you get the bags in place, you'll lower it some to get the bolts installed. Once you have the bags secured drop it again to install air compressor and lines.
I had my son help me so it was easier to hold the bags square and install the u bolts, but you can do it yourself.
Gave them a test and they work great. Compressor is quiet and efficient. You can hear it in the cab, which I like so I know if for sure air is being added. Takes about 65 seconds to go from 0 to 60 psi. Takes about 20 seconds or less to drop back to factory 5 psi that is a constant in computer.
