Engine Surge
My 6.2 engine surges from time to time. Only happens at very low speed, almost always when in a parking lot making a turn in to a space, etc.
Same thing happened with my 21 LTZ 5.3. Might be me but I have paid attention and have not observed anything I'm doing.
A little scary.
Thanks
Rick
Maybe expand a bit on “surge”? Noteworthy RPM jump? Brake slippage? Never had anything like this personally.
have you had others try to park it to see if it’s consistently happening? If others see it repeat for them, then I would recommend a trip to the dealer so they can see it happen and begin to debug it. If it doesn’t happen to others…need to check brake/skinny pedal foot contact when parking my friend 😅
Mine does it at startup every now and then. Will rev up to 2000-2500 rpms for a second or 2 before it goes back down. Never done it out of park though
What kind of floor mats do you have? Make sure nothing is inhibiting your throttle pedal.
I will say that the throttle tuning of these trucks is heavily slanted towards economy. Big delays are built in to filter out “unintended user throttle input”.
As a result power delivery at slow speed can be Surge-y. I’d do anything to go back to a physical throttle cable in modern cars.
Anything for the CAFES and the tailpipe emissions.
A little scary.
Thanks
Rick
Did you ever figure out what is causing this surge? Mine is doing it exactly as you describe.
Is there a fix to the surge?
A Throttle controller would negate the pre programmed delay.
Any new truck will drive like ass until the TCM completes the learn.
If you have a decent scanner you can also force a relearn. Which I would do if I ever bought a throttle controller.
The engine accelerates briefly, tends to surprise me when it happens. I don't believe my foot is on the gas when it happens.
I too have noticed the very same engine rpm surge, mainly in the parking lot ... strange...
It doesn't do it all the time just at low rpm.
Not buying the relearn thing . All my vehicles go through the learning thing and settle in unless I upset the curve. But the surge thing has happened since day one .. I have thought it would have gone away by now.. I have ten k miles now. One thing for sure the Range DFM delete makes for a smoother operating cycle !
I can't remember what thread but the poster said it turned out to be the cruise control buttons getting accidentally activated while parking or low speed turning.
Happens to me on occasion…I wear size 12 Crispi mountain boots (stiff with thick sole) and I occasionally will press gas and break simultaneously on all three of my trucks, no joke. Took me a minute to figure it out but it is/was all lead foot related.
I can vouch for this sketchy phenomena cause it happened to me just a few days ago in a parking lot while making a turn. I knew I had hit my cruise cause it accelerated right when I lifted off the throttle and was running the steering wheel across my open palm. I noticed the adaptive cruise message was on when I looked down at the DIC and started to brake.
Thanks for the laugh Bigfoot😂 I will check my feet next time for sure!
