Go Rhino RB 30s
I ordered a set of these and unfortunately I'm not a big fan. I like the look, but between them being "slim" and the inside edge being tucked pretty far under the body, there really isn't much to put your foot on. It's ok to get in the truck - but they are just about useless when getting out of the truck. Anyone else have these boards?
Running boards are like underwear...They only way you'll know if they are as comfy as they look is to try them on. Sometimes, they squash your nuts and ya gotta get rid of them.
that was my worry too… a bit too tight.
I ended up with Go Rhino D64049T - Dominator D6
They are definitely wider but are functional and are tucked up tight to body.
Only thing I don’t like is they come with 3 mounts vs 4. Called them and that is what they spec even though factory options come with 4
This is surprising. There are plenty of available mounting holed under the truck - and at least for my boards, you can attach them anywhere you want. I could have put 6 brackets on mine if I so chose . . .
