New Owner Question
This may be a dumb question but wondering if anyone knows what the yellow means on the tachometer. Not the incremental marks, but the yellow color that changes with speed and / or RPM . I'm not talking about the tach needle (rpm indicator). But there's a yellow color that shows up on the incremental hash marks. (I circled it in the picture - but note that I'm in PARK and not driving at that moment). I searched the owners manual but it doesn't say anything about that. Note... when I'm cruising at 60 mph, the bottom set of incremental hash marks are yellow and the RPM needle is up around 1800 (so I don't think it has anything to do with current RPM). On a side note, this is the smoothest shifting truck I've owned. 2025 Silverado 1500 ZR2 Bison
It looks like the recommended idle range to me?
I'm not sure I understand what you mean. Idle range..... when driving at 60mph? I do think it corresponds with the amount of work the engine is doing. But I was curious what it is actually indicating.
I'm talking about if a technician sets the idle in the truck, it supposed to fall in this range. I'm guessing of course. Maybe if the tech would change the fuel pump, etc.
I believe it just highlights the rpm range truck is in, speedo lights up same way. Congrats on new ride!
Yes, what Gator said. Just shows what RPM you are at. Speedometer does the same thing. Instead of having a bar that raises up with the RPMs or speed, those incremental marks change color to show that your RPMs or speed has passed that mark.
it's not the current RPM. That's what the needle shows. The yellow lit hash marks do not always coincide with the needle. Take a look at this picture. I was doing 38 mph, my RPM was 1300 (as shown by the needle) and only the 500RPM hash mark was lit yellow.
I'll have to take a picture when I'm doing 60 or so. See what the yellow is doing. Thanks
Gm could have done a better job with the gauge cluster, like actually make the whole sweep highlighted with hash marks so you know exactly what number it's on.
I saw this happen today on mine....I had 3 yellow at one point, then they went away when RPM dropped down....
