They are more or less the same truck. ZR2 has softer suspension, so you will need airbags probably. You are well with in the 8900 rating on the zr2. 6.2 is the same in both trims, Same transmission, same rear end, ect. The only real difference is with a high country you can add a max trailering package that steps up the rear end gear ratio to 3.42 vs the standard 3.23. With the 10speed GM themselves has said going up on the gear ratio makes very little difference though. I'd go with which ever trim you like the most. It's not like a high country is known for having a stiff suspension that handles heavy loads either.
I'm towing my boat with the ZR2 for the first time tomorrow. Much smaller boat than yours though, lol. It's about a 65mile haul for me with a small mountain in the middle. Not concerned at all. Truck handles my Tractor NP.
