I cant believe we are actually having this conversation but here you go:
Boyle's Law:
The relationship between pressure and volume in a gas is described by Boyle's Law, which states that at a constant temperature, the pressure and volume of a gas are inversely proportional. When a tire is compressed, its volume decreases, and therefore, the pressure of the air inside increases.
Load and Compression:
When a truck is loaded, the tires compress under the added weight. This compression reduces the tire's internal volume.
Minor Pressure Increase:
While the tire's volume does decrease slightly, the resulting pressure increase is typically not very significant, often only a few pounds per square inch (PSI).
Temperature Effects:
Tire pressure can also increase due to friction from driving, which heats the air inside the tire, causing it to expand and increase the pressure.
Here’s a little science experiment you can do to see it in real time for yourself:
Jack up one tire on your truck. If there is 45 PSI in it, put another 5 PSI in it for a total of 50.0 PSI. Make sure to use a digital gauge. Check it twice like Santa and verify it’s 50.0 PSI. Once you’ve confirmed it, lower the truck back down on the ground and check the pressure again. There will absolutely, positively be an increase in pressure. It may be 50.1 PSI but it will be an increase thus proving physics exists and Boyle’s Law is factual.
Let’s get back to the focus of the conversation of air bags and how
@AXE knows everything there is to know about air bags, he’s been there done it, been doing it for years and cannot possibly see a different use case for the ZR2 2500 than the way he uses it. There’s no need for jounces because they suck and the new part number is worthless marketing and the list goes on. It’s not that serious but if it makes you feel better, I’ll make sure to tag the entire forum in here and let them know that
@AXE told me so!
