Fender Flares
KLA
592
1,418
I'm sure this has been asked a bunch of times before, but I'm new to this forum and haven't had a chance to search yet. Have a 22 Silverado ZR2. Has anyone found a set of fender flares that will fit the ZR2 without modifications?
what do you mean by no modifications? bolt on?
Yes, bolt on, clip on, whatever. Just don't wanna get fender flares for a regular Silverado and have to cut and modify them to fit the ZR2.
check out AEV but they may be just for bison. FiberwerX makes some nice fiberglass stuff. not too much because of our unique front end. good luck. also try search here.
I wouldn’t see why any aftermarket flare wouldn’t work. Bedsides/fenders for the ZR2 are the same sheetmetal with holes punched for the factory ones.
You’ll just have open holes under the aftermarkets. I don’t think any application specific options exist.
hmm. thought we had unique front fenders due to bumper.
The regular Silverado fenders extend too far down on the front and that has to be modified on ours.
The Silverado ZR2 does have unique front fenders, and the normal Silverado fender flares won't work cause of the fender extending down farther than the bumper. But, I find it hard to believe that after 2-3 years in production, nobody makes fender flares specific to the Silverado ZR2. AEV makes fender flares kits for the Colorado ZR2, but not for the Silverado ZR2. The only other option that I have found is the wide fenders from Fiberwerx. But I don't really wanna go that route. I was hoping someone on this forum found riveted fender flares that are specific to the Silverado ZR2. But I guess they don't exist......
Wasn’t thinking about the bumper height. The fender itself is the same minus the holes. But the front plastic trim is shortened to accommodate it. Effectively changing the opening.
dude said he was looking for bolt on no cut. i kinda like the Fiberwerx fenders, price not bad but rears are too much imo.
Reactions: KLA
The Fiberwerx fenders are nice but I like the look of the riveted fender flares. Had them on my Trail Boss and was hoping to get them for my ZR2, but I guess I'm gonna have to find something different. Or get a set for a normal Silverado and modify them to fit my ZR2.
I’ve seen them on two trucks before:
But I think they modified regular silverado flares. The ZR2 is just so much of a smaller market that there isn’t much specifically designed for them.
Colorado at least got full Chevrolet performance support. What gives?
Exactly! You would think that after being in production for a few years that someone would make them.
Total BS. You can bet on the T1-2 ZR2 being a more baked offering than our Trail Boss+ pro max.
Different drum will play for that one.
Guess I'm just gonna have to get normal Silverado fender flares and cut down the front pair to fit the ZR2. The rear flares will fit no problem. It's just the fronts that need to be cut cause of the bumper.
I'll post up some pictures once I finally do it. Probably gonna do it in the next few weeks coming. My truck is all black so I might just leave them the flat black that they come in instead of painting them gloss black. The standard flat black will sorta match the stock flares that are on there now.
Decent body shop can cut the flares weld a section in and retexture the plastic so it’s uniform. Nothing is impossible.
I respect that. But I know what plastic welders cost.
The option is out there.
Yeah, you have a good point. I might have to look into a body shop like you said. It might be cheaper in the long run.
