- Oct 3, 2022
- 1,323
- 3,350
- #1
Hey guy, Finally getting around to doing a few things to my truck. Been waiting for parts to get my 2nd battery in. Working on that now then plan on doing my stereo, dash cam, ect. I also got my upfitter switches wired up. I connected those to the AUX battery vs running them of the starting battery. I'll probably just post a few pictures and what not on this thread as I go.
I do have a question though, Maybe someone on here will have some insight. My original plan for my AUX battery was to trigger the isolator after the engine was running. Best I can tell the stock circuit to do this is not present in my truck. If it is I sure can't find it. I found a circuit on the BCM marked as Auxiliary battery relay control on the electrical body builder manual for the truck. But after testing it, that circuit does nothing. So, I'm assuming my truck is missing some of the wiring or some other component somewhere. Not a huge deal and for now I just connected my isolator to one of the upfitter switches that's set to come on with the ignition. My isolator is 500 amp rated and the way it's wired it shouldn't matter if the starter pulls across it.
My question is though would anyone know where on the BCM to get a signal once the engine is actually running? I would like to have the isolator only kick on after the engine starts. With how I have it now, it powers up anytime you turn the key on. Course with the switch I can just turn it off. Which keeps the batteries separated even when the key is on. Might not matter, But in my mind if I pull my aux battery down and go to start my truck. As soon as I hit the start button, the batteries will be connected. Which would cause the aux battery to pull on the starting battery the same time the starter is also. Sorta of the point for the AUX battery is to be able to pull it down with out effecting starting the truck lol. Yes I can hit the upfitter switch and prevent that. But that adds another step. The only advantage I do see to this arrangement is if my starting battery is low for what ever reason (failed update maybe. lol) The AUX battery would act like a jumper. To me though ideally the two batteries would normally stay separated until the engine is running. I don't know maybe I'm over thinking it. What do you guys think. Should I bother with it, or just leave it like it is?
Here is a couple picture's of the battery install so far.
