- Dec 3, 2024
- 67
- 146
- Thread starter
- #21
Never take advice from a bot.
Huh? Are you sayin' that account is a bot, or that dude just copy pasta'd some AI generated BS from a Google search?
I'm pretty sure the installer would have wired it to a switched on power fuse.Does your amp have a switched remote on signal from the fusebox, or is it remote on sensing input from the speaker level? Just opening the door can turn on that amp, or any physical movement of any of the speaker drivers (air pressure, vibration, etc.) will create enough of a signal that the amp will turn on.
Yes, that account is a software bot backed my Machine Learning. We’ve had them on here before. They are designed to modify your position on topics, brands, products, way of thinking, etc. It is going to get worse over the coming years. You can spot them because their posts are “off” in some way as ML is still being dialed in.Huh? Are you sayin' that account is a bot, or that dude just copy pasta'd some AI generated BS from a Google search?
Odd. Why not just ban the account?Yes, that account is a software bot backed my Machine Learning. We’ve had them on here before. They are designed to modify your position on topics, brands, products, way of thinking, etc. It is going to get worse over the coming years. You can spot them because their posts are “off” in some way as ML is still being dialed in.
I’ll defer that to the mods. I remember when Elon bought Twitter he said he purged over 1 million bots and fake accounts. Eventually every forum will have auto bot detection and purging as the problem is going to get worse.Odd. Why not just ban the account?
I don't get it.
Thanks for posting that Tex. I did not catch it. AI sucks in my opinion, because I'm afraid of it and I don't understand it either!I’ll defer that to the mods. I remember when Elon bought Twitter he said he purged over 1 million bots and fake accounts. Eventually every forum will have auto bot detection and purging as the problem is going to get worse.
Correct! One key aspect of bots is frequently taking the counternposition and introducing crap information that may or may not pertain to the discussion. One things for certain, it's always information you've seen posted or presented in past articles. Never an original thought or organic post.Yes, that account is a software bot backed my Machine Learning. We’ve had them on here before. They are designed to modify your position on topics, brands, products, way of thinking, etc. It is going to get worse over the coming years. You can spot them because their posts are “off” in some way as ML is still being dialed in.
Wasn't me this time. LMFAO !!!!Peiple get mad when I call out the bots. I've even got DMs telling me I should be nicer to them.........LMFAO......nice bot, good boy!
Because most of the factory connections to integrate an aftermarket amp are located behind the back seat next to the factory amp, a shocking number of professional installers won't bother to run a dedicated 12v switched lead from the fusebox back to the amp location. This is likely not your culprit, just an observation since you mentioned an aftermarket amp was installed. Hope you find the problem.I'm pretty sure the installer would have wired it to a switched on power fuse.
I'll check the amp for any indicator lights the next time I open the door.
